Wireless Tally Systems
【Wide Compatibility with Various Switchers】Hollyland Tally System offers multiple port options, including DB25, RJ45, and USB-C, to support the connection to various switchers.
【Adaptive Frequency Hopping for Seamless Shooting】With the adaptive frequency hopping feature, this Wireless Tally system can detect interference in complicated scenarios, and hop to the channel with less interference to ensure stable signal transmission.
【Ultra-Long 2600ft (800m) Stable Transmission】With a stable transmission capability over a line of sight range of 800 meters, this Wireless Tally System can meet your needs for shooting in long-distance scenarios.
【Up to 16 Channels Supported】The wireless Tally box supports up to 16 channels. This allows for easy expansion or reduction in the number of Tally lights to accommodate projects of varying scales or complexities. *The DB25 port supports a maximum of 12 channels of dual-color Tally, while the RJ45 port can support up to 16 channels of dual-color Tally.
Wireless Tally System-4 Lights
$1,038.00
Wireless Tally System-8 Lights
$1,598.00
$1,038.00
NOTIFY ME WHEN AVAILABLE
$1,038.00
You Might Also Like
Astra P1 Pan-Tilt-Zoom Camera
Feature UHD 4K60 Face Detection AE 30x Optical Zoom AI Auto Tracking NDI®|HX3 Support ...
48 kHz/24-bit High Fidelity 3-Level Intelligent Noise Cancellation EQ & Reverb Adjustment Au...
Feature 48kHz/24 Bit AI Noise Cancellation Quick Charging Clip-and-Go AI Voice Tuning AI Auto-L...
