$139.00 $258.00
Add to Wishlist
  • [INCREDIBLY SMALL] Weighing just 9g, LARK M2 wireless lavalier microphone is the lightest mini microphone on the market. With its lossless sound reproduction and top-of-the-line recording capabilities, it brings you unmatched recording performance. The wireless audio transmission can reach up to 1,000ft line-of-sight range. Perfect for filmmakers, vloggers, and podcasters.
  • [Hi-Fi Studio-Grade Sound Quality] Designed for the Pro, LARK M2 microphone features a 48kHz/24bit audio format, capturing every sound with accuracy. With a 70dB signal-to-noise ratio, it ensures excellent audio signals with minimal background noise. Moreover, it can handle a Maximum 115dB Sound Pressure Level, perfect for recording in environments with high-pitched sounds.
  • [Extended 40H Battery Life] With optimized power efficiency, the LARK M2 wireless microphone delivers up to 10H continuous use (ENC off). The compact charging case provides 2 full recharges in under 1.5H per cycle, extending total runtime to 30H. Enjoy uninterrupted recording with our innovative power management system.
  • [Smart Control of Noise Cancellation] LARK M2 supports one-click on the yellow button to turn on/off the noise cancellation on TX and RX. The LarkSound app allows you to easily adjust noise cancellation levels (Strong/Low) to fit specific recording needs. Enhanced firmware and audio algorithms ensure crystal-clear, rich, and undistorted human voices, even in noisy environments.
  • [PLUG&PLAY] The LARK M2 wireless microphone system offers a direct plug on the receiver. It eliminates messy wires and provides a truly wireless recording experience. The receiver of the Lightning version boasts an MFi-certified Apple chip, while the USB-C version is designed for Android phones, Apple 15, action cameras, and computers, giving you a clear and crisp sound output.
  • [Instant Pairing Upon Unboxing] The LARK M2 microphone system is pre-paired at the factory, so you won't have to deal with any complex setup procedures. The transmitter and receiver will automatically pair with each other, allowing you to start recording right away. The user-friendly LarkSound APP allows firmware updates, volume and noise cancellation adjustments, and real-time audio status checking.
  • [TX Control for Video Recording] Pressing the Noise-cancellation button twice on the TX allows you to remotely control your phone to start or stop video recording or take photos. This feature offers a convenient way to capture your important moments in real-time. Note: Your phones must allow starting and ending video recording or taking photos with a single volume button press.
Please be aware that the present version of Lark M2 no longer includes the magnetic back clip.
-46%
Combo Version
Combo Version
$139.00 $258.00
-46%
Combo Version-Ivory White
$139.00 $258.00
-46%
Mini Combo
Mini Combo
$123.00 $228.00
-45%
Type-C Version
Type-C Version
$106.00 $196.00
-45%
Lightning Version
Lightning Version
$119.00 $220.00
$139.00
$258.00
Saved $119.00
