Pyro 7 Ultra
Pyro 7 Ultra
Pyro 7 Ultra
Pyro 7 Ultra
Pyro 7 Ultra
Pyro 7 Ultra
Pyro 7 Ultra
Pyro 7 Ultra
Pyro 7 Ultra
Pyro 7 Ultra
Pyro 7 Ultra
1 / 11
Pyro 7 Ultra
New
Master in One
$1,959.00
Add to Wishlist
Feature
  • TX · RX · Monitor
  • △E<1.5
  • QD-LCD
  • 1500nits
  • Focus Mode
  • 1,000m Range
  • 1 TX & Unlimited RX
  • Pyro Ecosystem
Product Description
Pyro 7 Ultra is an integrated 7-inch TX/RX monitor that delivers dual-flagship performance in both premium monitoring and cinema-grade wireless transmission. Its QD-LCD architecture ensures pristine, broadcast-grade color accuracy for high-end productions. Powered by its all-in-one TX/RX design and the robust performance of TWiFi, it eliminates the complexity of external wireless transmission setups while significantly reducing signal interference in demanding environments—delivering ultimate transmission control across elite on-camera, precision focus pulling, and mobile director monitoring workflows.
[Pristine Color. Calibrated for Pros.]
Delta E < 1.5 - Color Accuracy
Rec.709 - 99% Coverage [1]
Gamma 2.4 - Grayscale
1500 nits - Daylight-Viewable
95% DCI-P3 - Color Fidelity [2]
Delta E < 1.5: Every Pyro 7 Ultra undergoes rigorous factory calibration via Calman® software to deliver broadcast-grade reference standards right out of the box.
95% DCI-P3: Cinema-grade color with richer tones and smoother gradients for lifelike visuals.
Gamma 2.4: Enhanced midtone control and contrast for consistent, cinematic on-set monitoring.
1500 nits:  Clear viewing in outdoor and high-light conditions.
Ultra-accuracy. PC-Free. 3-Minute Calibration.Eliminate the pain of complex setups and mismatched third-party probes. As the industry's only fully integrated original ecosystem, simply plug the Hollyland Color Calibrator [3] via USB-C for PC-free, flawless color fidelity in just 3 minutes.
[1] 99% Rec.709 coverage — Refers to near-full coverage of the Rec.709 color space, the industry standard for SDR broadcast, television commercials, and online streaming content. This ensures accurate and consistent color reproduction across mainstream video workflows, with minimal color deviation from production to playback.
[2] ≥95% DCI-P3 coverage — Refers to high coverage of the DCI-P3 wide color gamut used in digital cinema and professional filmmaking. This enables a broader color gamut, producing more vivid colors, smoother tonal transitions, and more natural image rendering for cinematic production workflows.
[3] The Hollyland Color Calibrator is available as an optional accessory.
[TX · RX · Monitor  All-in-One ]-Master on-camera, focus pulling, and mobile director monitoring workflows with Pyro 7 Ultra—your all-in-one monitor and wireless transmission system.
[QD-LCD Optical Architecture for Exceptional Color Purity]-Pyro 7 Ultra incorporates a professional QD-LCD Optical Architecture, channeling blue LED light directly into a proprietary Quantum Dot Enhancement Film (QDEF). This specialized nanostructure converts the light into narrow-band red and green states to synthesize a high-purity RGB spectrum, delivering exceptional color purity with cinematic depth.
[HollyOS: Next-Gen Interactivity & Control]-Built for fast-paced professional workflows, the reimagined HollyOS UI drives direct, hardware-level display controls[4] and supports customizable templates with quick-toggle image analysis modules.
[4] Full display controls include Brightness, Contrast, Saturation, Sharpness, Exposure, Color Temperature, RGB Gain, Calibration.
[Image Analysis]-Advanced analysis tools [5] paired with granular parameter control for absolute on-set visual precision.
[5] Image Analysis features include Waveform, Histogram, Zebra, False Color, Rotate, LUT, Mirror, Anamorphic, Aspect, Safety Frame, Center Marker, Image Overlay, Grid, Focus Peaking, Sharpness.
[Camera Control]-By integrating official SDKs from leading camera brands, Pyro 7 Ultra unlocks a rich array of features with smooth, native responsiveness. You can effortlessly toggle control between the camera-top transmitter and wireless receiver— transitioning between local adjustments and long-range rigging to suit any scenario.
[TWiFi: Proprietary Dual-Band Transmission]-Proprietary TWiFi (Twin-WiFi) technology redefines signal resilience by establishing a synchronized "twin-path" across both 2.4G and 5G spectrums. This link triggers automatic frequency hopping to avoid congested channels in signal-heavy environments—unlocking the same extensive transmission distance, ultra-low latency, and unlimited receiver expansion proven by Pyro Ultra.
[Infinite Reach]
1 TX & Unlimited RX [6]
Range 3,300 ft (1km)
Dual-Band 2.4 GHz & 5 GHz
Ultra-Low Latency 20ms [7]
Video Transmission 4K60
[6] Supports 1 TX & Unlimited RX in Broadcast Mode only.
[7] Latency Values apply only when Focus Mode is enabled. Minimum latency under standard test conditions: ≥20 ms at 1080p25/30, ≥40 ms at 1080p60, and ≥45 ms at 4K60.
[Ecosystem & Integration]
Pyro Synergy. Seamlessly integrated with the Pyro ecosystem for streamlined multi-device pairing and an efficient wireless production workflow.
Professional Compatibility. Designed for professional production setups, with compatibility ranging from Sony VENICE series cameras to the Tilta Nucleus-M II Wireless Lens Control System.
[8] Compatible Pyro devices vary by operating mode. Non-Broadcast Mode: Pyro H, Pyro S, Pyro 5, Pyro 5 4K, Pyro 7, Pyro Ultra, and Vcore. Broadcast Mode: Pyro S, Pyro 5, Pyro 5 4K, Pyro 7, and Pyro Ultra.
[Review Instantly. Direct Remotely]
Video Playback
Record video on set and review footage instantly with precision playback.
On-screen Markers
Mark shots to coordinate scenes remotely, eliminating the need for constant on-site adjustments.
[All-Scenario Adaptability]
Pyro 7 Ultra features HDMI/SDI cross-conversion for flexible signal routing, while an integrated V-mount plate and DC input ensure non-stop powering in any environment.
Pyro 7 Ultra
Pyro 7 Ultra
$1,959.00
Pyro 7 Ultra
$1,959.00
