$514.00 $1,072.00
Add to Wishlist
  1. ENC Noise Reduction
    • Solidcom SE features an ENC dual - mic noise reduction design. It can dynamically recognize environmental noise with a noise reduction depth of up to 20dB.
  2. Clear Call Quality
    • It offers clear calls, with a frequency response range of 150Hz - 7KHz and a signal - to - noise ratio > 71dB.
  3. Waterproof and Design
    • With an IPX4 - level waterproof design, the overall headphone adopts precise industrial design.
  4. Automatic Frequency Tuning
    • Equipped with an automatic frequency - tuning algorithm, it can automatically adjust the frequency when encountering interference and has a 350m transmission distance without visual - range obstruction.
  5. Easy to Use
    • It is ready to use right after being powered on. It supports up to 5 - way collaborative communication.
  6. Mute Function
    • There are two mute options: the MUTE button and muting by flipping up the microphone boom. The MUTE button supports the PTT mode.
  7. Battery Life
    • The fully - charged headphone has a battery life of up to 12 hours and supports charging while using.
Note: The set includes a carrying case.
-52%
🔥Solidcom SE-4S
🔥Solidcom SE-4S
$514.00 $1,072.00
-58%
Solidcom SE-5S
Solidcom SE-5S
$649.00 $1,582.00
Solidcom SE-2S
Solidcom SE-2S
$257.00
-39%
Stereo Remote Headset Single-Ear
$167.00 $278.00
$514.00
$1,072.00
Saved $558.00
