Astra P1 Pan-Tilt-Zoom Camera
1 / 12
New
Professional Precision. Effortless Motion.
$2,798.00
Add to Wishlist
Feature
  • UHD 4K60
  • Face Detection AE
  • 30x Optical Zoom
  • AI Auto Tracking
  • NDI®|HX3 Support
  • Optional PTZ Controller
  • Ease of Use
  • 5-Year Warranty
Product Description
The Astra P1 PTZ combines a high-performance UHD 4K60 imaging system and 30x optical zoom with intelligent face-detection AE and AI auto-tracking. With support for NDI®|HX3 and diverse I/O interfaces, it is a comprehensive professional solution for churches, halls, various live events, and beyond.
[UHD 4K60]-Cinema Clarity. Shine in Shadows.
Live venues aren’t always well lit — halls, auditoriums, and churches often present challenging and complex lighting environments. The Astra P1’s 1/1.8” sensor increases per-pixel light intake to deliver crisp, noise-free 4K footage.
[Face Detection AE]-Exposure That Stays With You
The light shifts, but the target stays bright. The Astra P1 intelligently tracks the performer and optimizes exposure in real-time. In low-light settings, auto exposure simplifies your team’s workflow. At least it's one less thing for you to worry about with the Astra P1.
[30x Optical Zoom]-All in 4K Detail
Go from a wide shot to a close-up with clarity in every pixel. Powered by a 30x optical lens with an aperture up to f/1.6, the Astra P1 gathers impressive light even when zoomed to the max. Combined with 16x digital zoom and 0.1° preset accuracy, it switches between long-shot and extreme close-up presets with fluid motion.
[AI Auto Tracking]-Locks on the Presenter. Tracks Every Move.
Presenter Tracking:
The Astra P1 uses human-based logic to follow the presenter, analyzing posture and motion to distinguish them from the background. In crowded environments or complex setups, it maintains a precise lock on every move.
Zone Tracking:
Define up to 4 key areas (podium, whiteboard, demo table, etc.). The Astra P1 then tracks between them as the target moves to provide a smooth transition in large spaces. Ideal for large auditoriums where a single operator needs reliable, automatic coverage.
[NDI®|HX3 Support]-Pro Connectivity. No Licenses Needed.
An NDI®|HX3 license is included with every Astra P1 — no extra cost. Just connect one Ethernet cable to stream near-lossless 4K video with ultra-low latency. The Astra P1 integrates into your NDI workflow, ready for vMix, OBS, or any professional broadcast studio.
*NDI® is a registered trademark of NewTek, Inc. Network services and third-party software are subject to their respective terms and conditions and may change without notice.
[Web Control]
Every Setting in One View:
Open a browser tab on your computer for full access to your control panel. Pan, tilt, zoom, and manage every professional setting remotely.
Power of One:
A single PoE+ cable delivers 4K video, audio, power, and control.
Broadcast-Grade I/O & Protocol Support
The Astra P1 supports simultaneous output via HDMI 2.0, 3G-SDI, USB, and LAN. It delivers up to three independent HD streams and supports a full range of protocols, from standard VISCA/Pelco for control systems to USB UVC, IP-based streaming, and FreeD for AR/VR virtual production.
Any Workflow. Every Stage.
Output independent main and sub streams to handle high-quality recording and low-latency monitoring at once. Whether in churches, halls, or live events, the Astra P1 is built to perform in any professional setup.
[5‑Year Warranty]-FAE Instant Support
Every Astra P1 includes a 3-year standard warranty, with an extra 2 years available through product registration. Our field application engineers are on standby to provide instant technical support. At Hollyland, your vision is our mission. We are committed to your long-term success.
$2,798.00
$2,798.00
