- Full-duplex Communication
- 500m Transmission Range
- High-quality Audio
- Hub Cascading and Expansion Interfaces
- Roaming Functionality
- Multiple Power Supply Options
- UAC Function via USB
- Upgrade Options
- Flexible Configuration
Solidcom C1 Pro - Roaming Hub 10S (V-mount)
$15,162.73
Solidcom C1 Pro - Roaming Hub 20S (V-mount)
$20,095.00
Solidcom Roaming Hub (V-mount)
$9,598.00
$15,162.73
NOTIFY ME WHEN AVAILABLE
$15,162.73
You Might Also Like
Astra P1 Pan-Tilt-Zoom Camera
Feature UHD 4K60 Face Detection AE 30x Optical Zoom AI Auto Tracking NDI®|HX3 Support ...
48 kHz/24-bit High Fidelity 3-Level Intelligent Noise Cancellation EQ & Reverb Adjustment Au...
Feature 48kHz/24 Bit AI Noise Cancellation Quick Charging Clip-and-Go AI Voice Tuning AI Auto-L...
