{"product_id":"mars-4k","title":"Mars 4K","description":"\u003cul\u003e\n\u003cli\u003e\n\u003cb\u003e4K UHD Video Transmission.\u003c\/b\u003e Mars 4K is the first 4K video transmission system from Hollyland. It enables sharp and detail-rich images for a splendid monitoring experience.\u003c\/li\u003e\n\u003cli\u003e\n\u003cb\u003e450ft (150m) LOS Range.\u003c\/b\u003e The transmission distance of Mars 4K is up to 450ft. It's able to cover a scenery of soccer field size.\u003c\/li\u003e\n\u003cli\u003e\n\u003cb\u003e0.06s Low Latency.\u003c\/b\u003e Mars 4K transmits 4K video images in real-time with only a 0.06s delay. \u003c\/li\u003e\n\u003cli\u003e\n\u003cb\u003eSDI \u0026amp; HDMI Support.\u003c\/b\u003e With SDI and HDMI dual interfaces, Mars 4K is a perfect solution for both DSLRs and high-end cinema cameras.\u003c\/li\u003e\n\u003cli\u003e\n\u003cb\u003eBroadcast \u0026amp; Production Frame Rate.\u003c\/b\u003e Mars 4K supports decimal-point frame rates to facilitate professional video production at the broadcasting level.\u003c\/li\u003e\n\u003cli\u003e\n\u003cb\u003eFlexible Monitoring Options.\u003c\/b\u003e Mars 4K allows connection with RXs or mobiles\/Tablets. It's able to connect with 2 receivers simultaneously. When connected to one receiver only, the transmitter can connect two phones\/tablets via the Hollyview app. If no receivers are connected, Mars 4K transmitter can connect 4 mobile devices in total.\u003c\/li\u003e\n\u003cli\u003e\n\u003cb\u003eSmart Channel Scan \u0026amp; Selection.\u003c\/b\u003e Stable connection and reliable transmission are available upon startup.  Mars 4K will scan available channels and auto-select the most robust one to build a connection.\u003c\/li\u003e\n\u003cli\u003e\n\u003cb\u003eMultiple Power Supply Options.\u003c\/b\u003e Mars 4K can be powered up via multiple options, including NP-F batteries, DC Adapter of \u003cspan\u003e6V to 16V, and Type-C charger of 5V 2.5A.\u003c\/span\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e","brand":"Hollyland Store(CA)","offers":[{"title":"Mars 4K Kit","offer_id":48628243038447,"sku":"CA-Mars 4K-1T1","price":559.0,"currency_code":"CAD","in_stock":true},{"title":"Mars 4K Transmitter","offer_id":48702235672815,"sku":"CA-Mars 4K-TX","price":293.0,"currency_code":"CAD","in_stock":false},{"title":"Mars 4K Receiver","offer_id":48702235705583,"sku":"CA-Mars 4K-RX","price":293.0,"currency_code":"CAD","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0811\/1017\/1887\/files\/9802G-mars_4k-clear-001.png?v=1776060155","url":"https:\/\/ca.hollyland.com\/products\/mars-4k","provider":"Hollyland Store(CA)","version":"1.0","type":"link"}
